increasing T3 vanagon stability
giuguar, Montag, 21. Mai 2012, 04:05 (vor 5072 Tagen)
Hello everybody,
sorry if I don't write in german but I don't know your language and I need some help.
I own a T3 westfalia TD1.6, at the moment I'm renewing the engine; after that I'm going to renew schock absorbers coils etc. In order to increase stability I don't want to modify the height of suspensions so I would like to add some spacers between the disk brake and the wheel to enlarge a bit the distance between wheels, I suppose this, together with larger tyres will increase stability. Do you think is this causing some damage in a long while to the steering or the brackets of the schock absorbers or whateverelse? I need you opinion guys!
Thanks for your time.
Giulio
